Iridium spark plugs
syclonekid43
SY2455 said:
I can tell you I really like them I'm running the UR6IX part #7348 right now & I went from changing plug every 4 months to 6 months & counting, but I also have a MSD 6A installed (hidden from view). The truck runs so much better that I change all my vehicles over to them.
stock motor?
Dr.Evil
Addicted to Boost
I have been running the NGK Iridiums in my SHO and they work well with the N20. I picked up a set for my Ty today...hopefully they will help the off-idle stumble. I picked them up at Summit for 6.99 each.
SY2455
70's Veteran
roberto said:
stock motor?
Yes it's stock except for reliability up grades: AFPR, KB Air filter relocation kit, Bigger Fuel pump, MSD-6A, After Cat Exhaust,Intercooler pump running with engine running, Custom-built Road Kill Scoop for Intercooler heat exchanger, now my intercooler doesn't get hot even after running it hard.
http://www.nwstp.com/oldsite/scoop.html
Syclone Rob
Its all ABOOT the SYTY eh
When I got my truck last year I installed the NGK Uridiums. My truck is Stock with on a K&n filter in the original filter housing. Right away I noticed an improvement in the idle. Plus my knock is almost not there totally..
Here is a datamaster run the day after I did the tune up (only wires and plugs) otherwise stock. Plus the intercooler pump was dead in this run (which I didn't know at the time, hence the higher intake temps)
right click save-as
http://www.robbiet.no-ip.com/syty/robtest2.uni
Next week I'm going to replace the wires and plugs so I can examine them to determine how much wear they have gotten over 3500 miles. If they last as long as some say this will tell me. :rock:
here is the original thread I posted
http://sytynet2.phpwebhosting.com/phpBB2/viewtopic.php?t=36599&highlight=
Rob
SY2455
70's Veteran
right click save-as
http://sytynet2.phpwebhosting.com/phpBB2/viewtopic.php?t=36599&highlight=Rob
Rod, how many miles you have on you truck? do you have a weird Idle at all? On my truck, I used the NGK UR5 reg plug & the truck had a weird Idle almost like a miss,sometimes the truck was hard to start in the winter (It gets down to 15 degrees sometimes here) but everything check OK so I added the MSD-6A before changing over to the NGK Iridium UR6IX part #7348. The MSD-6A took away my weird Idle & cure my cold start problem. The Iridium plugs gave me better performance & mileage & I don't have to change them as often (Now that I think about it I'm still on my 1st set).
Syclone Rob
My truck has 24800 miles on it... No I don't have a weird idle... the engine shakes ever so little.. (much better then before the tune up) but it doesn't miss... I am using UR5IX plug. I don't drive the truck in the winter so I don't know about the cold startup.
Rob
