Re: is this to lean
Yes*
I would aim for 11.7-12.3 @ WOT. What was your KR with that AFR? What boost level? What timing? What fuel pressure? What injectors? What turbo? If all other things are normal, you have a fuel pressure, fuel pump, fuel filter, VE map, etc....problem. I would cure this before making anymore WOT blasts as severe knock, piston meltdown, rod bearing failure, etc.....is in your near future with that AFR.
* If you were running VERY low boost & timing, this could be within the upper realm of acceptability, but I feel sure you would've mentioned that if it had been less than normal boost or timing.
Hood
