Foot Performance
I am drilling the 4th hole on the tubo and was wondering how deep to drill the hole or do i go all the way threw???
Any help would be appriciated :tup:
George Blake said:I drilled mine through all the way. I figured it would be easier to get out later if I could access the threaded end to apply heat and oil or pb blast.
Foot Performance said:I used a cut off tool and cut strait down to the puck and then grinded the lower puck weld off and it hammered out I can get a pic of mine if you want
Loeryder said:I had the same question just haven't pulled mine back apart to drill it out yet.
Jeff do you have the pic posted of the "rib" section you removed from yours?
TwinTurboV8Ty said:Nice downpipe, where did you get it?
Roy did it almost exactly how I do them.
