KB air intake vs. Stock crossover setup
djsan67n808
ohh and one more question... in the sportsmachine link for the installation for the kb intake... the "parts required" list . those parts are not included in the kit??
djsan67n808
Matthew Little
kb intake
kb intake
I am not in love with the kb kit on my truck,but I have done a few things to make it perform better,and with the other option being relocate the Battery to the lower fender,if you don't want to get to your Battery go buy a dodge car. They have put alot of stuff in the engine compartment,and not much room for anything else. To kind of help out with the Street/strip thing, A drag truck with a filter right on the front of the turbo or none at all would be better when there are not things,like heat soak from sitting in traffic,or driving at low speeds. Going down the track in 10-12sec sure pulls alot of air in the turbo(hot or cool).
It sometime seems to be forgotten that we do all these things to make the intercooler work better(fans,xtra cche,more fluid, etc) and then let the filter suck in 130-150 deg air causing the intercooler to be less effective.??? Just what I have noticed.
djsan67n808
what are the pluses. for the KB intake kit.... nobodys selling a fully stock plastic crossover pipe soo i might just buy the kit.. if its worth it
Matthew Little
kb
kb
That is not a cold air kit,it is a hot air one!
smeagol wrote:
2- relocate your battery somehow, turn orange turbo hose towards passenger fenderwell and put a cone filter there. If you do an aftermarket turbo setup, chances are you'll have to do this anyways.
Lynn D. Brown
My Don,
I did the Batt Relo (had to w the PTE-63) and just put in a Cobra elbow that goes right into a K&N cone w a 4" inlet. Now I gotta figure how to shield it from engine heat - probably use some kinda sheeting, fiberglas, etc. A narrow Yellow Top Batt. will be under all of this.
I even fit the bigger Griffin Rad in there w the top trans cooler connection, but God that was a tough fit w alot of Mods required.
smeagol
Re: kb
Re: kb
You're right. There is NO good cold air kit available, but this route opens up a lot of options, and I am betting you won't see any huge performance gains with any of the options you have in this discussion.
Anyways, this is the best solution you will have, if you are budgeted for money and time invested. Beyond this, go cut your fenderwell, as per Morgan, or Daron, or Gary Shanock.
Spending hours discussing cold air kits reeks of rice IMO... this coming from a Toyota owner :wink:
The only ideas worth spending this sort of time & research is some sort of ram air design. It's essentially free forced induction; and yes it can still help a turbocharged vehicle. Increasing pressure at the inlet of a turbo will greatly increase the efficiency of a turbo.
Matthew Little
kb
kb
As far as performance,my buddy just got a 1000 horse dyno,so I when I do my truck I can do an extra run without the kb filter cover. I spent alot of time tring some things on the filter intake,and ending up making a scoop thats feeds into the inner fender and is directed into the kb box. That bad a huge diff in intake temps,as I can look at scoop temps,k+n box temps and iat,just to see what it was doing for good if any. everthing rice is not bad,as I own a turbo dsm and a 2 nissan's. One of which is my avitar and much cheaper to build and race than the truck. Most of the temps I saw where during this summer and made the heat soak in the filter and intake go down quicly. My iat temps went from starting high and going low to being around amb. and raising 10-12 deg on 0-100 runs, but I have a small cfm turbo too. For me I was satisfied with what my scoop did for the truck and was cheep to build.
tallcoolone
fenderwall cutout
fenderwall cutout
Something I did..left battery in place..cut hole in fenderwell,put screen over it and ran K&N to turbo..no problems..then cut out heat shielding to keep heat away from K&N/tube leading to turbo
