keeps bending push rods!!
jwaller
Evil Genius/SyTy Guru
Re: keeps bending push rods!!
the 850's will not work(in the long haul). I have broken several and so have several other members. I believe thats what comp recommends but they are only stock replacements, not a performance lifter. if you have the 850's get them out before you have more problems. I had them(850's) explode as did other members here. at a min you need the 875's
cloneman315
what is the difference john .i hope i dont have them in my new motor what should i do if they are in tere
BoostedSUV
#1, #2, #6 intake keep "loosening" up..... Same ones that bent the pushrods before the heads were machined! It's not possible to have 3 bad brand new lifters is it?? Maybe pulling out the pressed in rocker studs?
jwaller
you might be pulling out the studs, I would definatly check for that, another reason I always convert to screw in's.
The main differance in the rockers is the capture device used to secure the cup that the pushrods sits in. 875's use a normal split ring type clip and the 850's use the stock style retainer. it's that piece that comes out allowing the lifter to shoot it's guts into the motor.
BoostedSUV
I fixed this problem a while a ago.. the head studs were pulling out of the head and creating a lot of valve lash. I tapped the heads and installed screw in rocker studs... problem solved!
