Knock Battles!!!!!
johnboy89
Re: Knock Battles!!!!!
So the battle continues with this:banghead::banghead:
Installed wideband and readings are 10.3-10.9 or so!!!!!
Knock is somewhat intermittent and worse when on the go...........
Put a can of that TORCO in the tank and all I can say is WOW, if anybody had any doubts about this stuff I can tell you it works!!!!
So with this being said the KR is real, but I'm not sure where to go from here???? Compression check I think will be next.
Anybody have any other thoughts???
Thanx:D
Static
I feel your pain. Im in the same boat as you. Fueling in the 10s. Compression test is the next thing on my to do list.
SYCLONE#1531
'MOFOFAST
Im a true believer of the stough. I ran 28 degrees timing and 27lbs on 93 mixed with Torco Accelerator + spraying meth. Good luck with your truck!:D
Thanx:D
johnboy89
So took the time today to do a compression test on one cylinder and my reading was 180 PSI. (engine cold)
From searching most folks with stock trucks seem to see around 150 PSI or so????
My guess is that this is what's causing my knock???? Not sure what 180 PSI comes out to for a compressoin ratio, but I'm sure it's higher than stock!!!!
I did use the dished Speed Pro Pistons #L2441F30, but I'm thinking the block and heads have been milled a few times before causing the higher numbers???
I have noticed that my truck is very responsive light throttle and gas mileage not that bad!!!
I guess at this point I have to either use Torco or use Alky Injection???
Thoughts???
Thanx:)
If you have a higher compression ratio than stock, you can lower the boost for pump gas. Your using code 59 for tuning, so I would do that first.
IpHoOnDyou
To do a proper compression test, 1. Engine needs to be or at operating temp 2. ALL spark plugs need to be removed from the engine to do a proper compression test 3. If you want to verify proper cylinder compression add a squirt or two of oil to the tested cylinder an see if compression goes up or down. The reason your compression is so high when the engine was cold was because when steel is cold it contracts, as it heats up it exspands. In therory your test is inconclusive an has given you no answer. I recomend going back an doing your compression test over again.
Steve
johnboy89
If you want to verify proper cylinder compression add a squirt or two of oil to the tested cylinder an see if compression goes up or down. The reason your compression is so high when the engine was cold was because when steel is cold it contracts, as it heats up it exspands.Steve
I'm no expert, but never have heard of compression readings going down by adding oil, I was always under the assumption you add oil to see if the reading goes up??? Also always thought readings woud be lower when cold and go up as the engine heats up???
johnboy89
Interesting. When I first got that truck running back in 2000, I was constantly fighting knock and knock retard. It got super fuel economy (22+ MPG) and ran pretty good at GB 2001 with VP 100LL for fuel. I remember noting that cranking compression pressure was in the 180's and asked the "gurus" here if they thought that might have something to do with it? Anyway, upon tear-down of that engine, I discovered it had had flat-top pistons installed. 9.5 CR. Guess I answered my own question. I installed a complete Ty engine from a parts car. That engine was in it when you purchased it. IIRC, the cranking compression of a stock SyTy is about 145-150psi. The stock engine was definitely not as fast, didn't knock as readily, and didn't get near the fuel economy the high-compression engine did.
I have no idea why you're getting 180psi cranking compression, but it's not because the engine is cold. I've never seen an appreciable difference between cold and hot engine cranking compression.
With 180psi cranking pressure, that definitely has something to do with your chronic knock trouble at 15 psi boost on pump gas. It did for me over 10 years ago in the same Ty..
Do you have any pics of the chambers which you could compare to pics of non-machined heads of the same casting? May be able to tell if heavy machining has been performed.
Unfortuanetly don't have pics of the heads before I put them on.
I do know the block was machined when I rebuilt it and I bet the heads have been before too, how many times who knows, but willing to bet enough to raise the compression????
One of the first things I noticed after I rebuilt it was how much quicker it felt than before!!! I thought it was maybe because of the L35 heads........
I've never actually calculated my MPG, but if I had to guess I'd say it's close to 20, I'll check it on the next fill.
Running it with Torco has completely eliminated the knock for the most part, so I'll either have to continue with that spray it or lower boost some more????
