KNOCK.... counter/retard
Quickstop [UK]
Combating adversyty.
Re: KNOCK.... counter/retard
I'm no expert but it sound like resonance. At 2800 - 3300 rpm you are probably right in the band where something is rattling then when you get faster it goes out of the band.
Seeing as you are not even under load (idling) it does sound like false knock. What are your intake temps like?
I'm leaning the same way that it's some sort of resonance or noisy lifters.
That day was in the 90's and my temps were 110-115. Keep inmind that it was in the driveway when I recorded the data above. An earlier recording the same day while driving shows more like 105-110 and dropping to high 80's as I let off the gas to slow down.
One more note, I noticed the knock was around each of the shift points just slightly before shifting. Probably just due to the higher rpm's and it's just coincidental.
After running the Xylene for 40 miles or so I noticed a smoother sound and feel to the way it runs. Knock is still there so I am almost certain that it's false. I think it'll be ok at the track Tuesday. I'll post the timeslips when I get home.
