Knock problem
bshaw1979
Re: Knock problem
I would start by trying to figure out if it's real knock. The off-the-shelf octane boosters aren't always the greatest, however it might be enough to tell you if it gets better. If adding octane improves the knock, then we can move on to the tune.
If it's in the tune, it's easy enough to make some tweaks, or I can swap chips with you if necessary.
Regards,
Eric
Thanks eric. Its gonna rain here for the next few days so i will have to try and add some race gas this weekend. I will see if i can get a data master log of it and go from there. Im pretty sure the kr is real but i guess that will tell me for sure.
bshaw1979
Re: Knock problem
Just a quick update on my knock issues.I would usually get up to the 5-8kr range. The first time this year i took the ty out i did a tune up on it. Plugs , wires, cap, rotor ,and a new msd coil. I went with ur6's instead of ur5"s. Checked the timing also. So i went out for a spin to log some data and the highest kr i saw was around 2. Im guessing it was the plugs that helped but I'm not sure. Im just glad that after battling for 2 years with this damn truck i can start to really dial it in.
