Knock Q??? with Meth spray?
attackdog
Hi all . In my signature you can see what has been done to the SY. With that said, I am getting some knock at WOT. So do I turn up the Methanol spray or should I turn it down? I have had the SY for 5 years now and still can't figure out how everything works. Thanks.
-Dean
BMFB
Not to scale
Re: Knock Q??? with Math spray?
that depends, you can knock from being to lean, as well as from being to rich.
Syclone#2960
What ever it takes!!
Re: Knock Q??? with Meth spray?
up until you start getting ignition break up...then you would back it down. I usually use my scan tool to watch the intake temps drop as it sprays. I personally try to use the least amount as possible as to avoid washing out the cylinder wall from oil.
