Houseofperformance
switchhappy!!!
Hello to the board!
I´m the owner of sy2307 here in Austria. I bought the car 3 month ago with a blown headgasket. While changing the headgasket I noticed that the knock sensor is not mounted where it´s suposed to be. I searched for the hole in the block right next to the oil fitting behind the distributor, but no hole there. Right now the sensor is mounted on a bracket on the last bolt of the lower intake facing downward to the tranny.
I don´t know if the sensor is able to work right in this position. I don´t get any trouble codes and the truck is running strong, but I rather play on the save side. I just got my ultimate v8 along with the FP and FPR from RPM and want everything to work right before I install it. So what do you suggest?
Should I leave the knocksensor in this position or drill a hole in the block to mount it in it´s OG position or just weld a nut on the block an screw it in there?
Is it possible to "test" the sensor if it is in working order?
Please help!
TIA
Joerg
Please help!
TIA
Joerg
