Lean idle FIXED!!
Lately the truck has gotten this weird trait where it goes lean at idle. It can idle just fine for a moment and go clear lean on the WB. Now I have reduced FP a bit so it could be that but I'm wondering if a bad o2 could be causing this?
Truck runs fine off idle. Only happens when throttle is closed. Bad TPS maybe?
I'll pull the o2 and look at it and I may even wire up the emulator of the PLX as a test.
DM is inop right now so just wondering what you guys might think...
Thx
sytyguy
Moderated User
Re: Lean idle
Re: Lean idle
Forgive me, but a few questions:
Code58 or Code59?
Open Loop tune or Closed Loop?
If Closed Loop and Code59, is WB wired to ECM and being used for Closed Loop?
It would be weird if it was the TPS, as normally that will command a richer idle if the TPS is reporting a higher voltage than 0.5 (what it should be (or close) when throttle is closed). My thought is it could be O2, but my advice would be to raise fuel pressure back up and see if problem persists. If TPS or O2, it should not go away.
Re: Lean idle
Re: Lean idle
Code58 or Code59?
Chip is a multi-tune chip from Mike at RPM. (Haven't changed the selection I'm using in ages.) WB is wired to the ECM but, I believe, only for output to DM. I can certainly raise the FP back up but just that you say it could be the o2 helps.
Wish DM hadn't quit. I'm gonna post in parts wanted and see what happens.
sytyguy
Moderated User
Re: Lean idle
Re: Lean idle
DM quit....as in laptop died or ALDL cable died? USB or Serial cable?
In any case, I'd raise fuel pressure and observe with gauge.
Re: Lean idle
Re: Lean idle
Serial cable. The test software from TTS shows port is active but it fails every test that it runs. I just posted a in parts wanted for one. Laptop runs fine, haven't changed any settings.
Damian
Re: Lean idle
Re: Lean idle
I'm unfamiliar with DM, but try to reinstall the cable software and see if that helps. Or reinstall DM all together.
Re: Lean idle UPDATE
OK wired the narrow band output from the WB into the ECM and all seems well. I learned a long time ago that one can never be completely sure an issue like this actually fixed but driving around for about 20 mins with a couple of FT pulls to 60+ then idling the WB stayed near 14-15. This with 5# less FB. (40# with vac line off instead of 45#)
Only thing now is to wait until I get DM working (cable on the way, thx Richard!). Seems to run smother though. WB before mod jumped around a LOT. Now it's settled down noticeably.
Re: Lean idle NEW QUESTION
OK, been running on the emulated o2 and it's still doing this lean idle thing just not as often, Hard to tell but it SEEMS it might be temperature related. I'm wondering if the IAT probe is sending false signals? Yesterday just driving around the IATs were in the 120+ range. Seemed hot to me.
Thoughts??
sytyguy
Moderated User
IAT sensor will have a degree of control, but usually it fails in the opposite direction (reporting -40degC and causing a rich condition everywhere). Easy enough to check, backprobe the sensor with a volt meter and check it. 0-5v sensor with 35degC/volt linear temp correlation. What I mean is that the sensor will report like so:
0.0v = -040.0 degC (-40 degF)
0.5v = -022.5 degC (-09 degF)
1.0v = -005.0 degC (+23 degF)
1.5v = +012.5 degC (+55 degF)
2.0v = +030.0 degC (+86 degF)
2.5v = +047.5 degC (+118 degF)
3.0v = +065.0 degC (+149 degF)
3.5v = +082.5 degC (+181 degF)
4.0v = +100.0 degC (+212 degF)
4.5v = +117.5 degC (+244 degF)
5.0v = +135.0 degC (+275 degF)
So, just cruising around, you should see around 2.0v-2.5v. If you're seeing wild movements in voltage or something way too high for the temp you should be seeing, then you may have a faulty sensor. Standard PN AX1 if you do.
Do all that.....or get your cable fixed and datalog temp.
Update, threw a IAT sender at it, no help. OK, fine, be that way. Got out the book and started testing the TPS. (what I shuda done with the IAT sensor) Numbers are at the shop but the first thing the manual says is if the idle reading above (whatever the number is) then replace the TPS. It also reads low on full throttle volts even though DM shows 100%. Wiring checks OK per the manual. I ordered a new TPS and its going on today, I'll let you know if it makes any difference.
sytyguy
Moderated User
Potentiometers (TPS) are very simple devices and are quite easy to diagnose. However, most TPS failures I have seen are erratic in nature. The problem you describe sounds much more predictable and repeatable, which leads me to believe it's probably not TPS. I'm hopeful it is though as that's an easy fix.
I may have overlooked it, but I never saw where you raised FP back up Don. If you did, did it have any measurable affect on the lean condition? Have you gotten your cable back yet? If not, I'll overnight you mine so that you can quit throwing darts and get some sound info on the condition.
I do have a cable now. Thanks. The TPS NAPA sold me was the wrong one. Gave them the correct GM# and the NAPA Echlin equiv will be here tomorrow.
No, I have not raised FP all the way back, only partially. What's irritating is the idle will be fine. Clicking right along 14-15 on the WB, running like it always has. Blip the throttle, or more likely, do a restart and motor is almost dieing because it's lean. I'll try it with the ECM down in case there's a wire being pulled or something but I don't think that's it. Once the the TPS is in I'll test and post a log. Right now truck and computer are at the shop.
Appreciate the comments.
Flyin Ryan
hated cuz he drives fords
long shot but did you reset the chip into the ecm and pull the fuse and allow it to relearn?
Yes, more than once. BUT not during this current issue. I'll do that tomorrow. I have two ECM's also. Currently on #2. Original on the bench. Might throw that back in also. But first comes the TPS. I have DM traces (key on engine off, read TPS volts at idle and FT.) and will compare them to the new one.
bezerk
Re: Lean idle UPDATED DM added
u sure you don't have a vacuum leak? your iac counts are kinda high.
I imagine they're high because the ECM is attempting to keep the motor running. Yes, no?
Did you see how much the o2MV changes before and after restart? I wonder if that's the source of the issue? What I don't know is why. What would cause that? Remember this problem didn't go away when I switched the ECM o2 signal from the stock ECM to the emulated o2 from the wide band.
Thanks
bezerk
Its high from the beginning, should be around 30 yours 127, i would bicycle tube test it.
Re: Lean idle FIXED!!
After much head scratching I changed the o2 sensor and all is well. Motor runs better, idles much better. Did one boost launch and even that felt better. Will have make a pass at the track to confirm. Old o2 even looked bad, like it had been to hot. I'm thinking I'll reposition it further away from the turbo this winter.
