Re: LED Knock Sensor
I'm sure someone with more electrical knowledge could wire one up. That IC is a hex buffer/inverter. The LED circuit only uses one input/output of it. It's basically just taking the knock signal from the ESC, inverting it, and using that to light up the LED. I believe you could do it with a transistor(s) rather than the IC. Back when I was researching it, someone said that it will actually blink faster the more knock there is. Not quite as good as a series of LEDs like you want, but it does tell you slightly more than just whether there is or isn't knock retard.
