brock1949
Its alive!!!
I know this has came up time and time again, I spent hours searching this forum and i'm coming up with so so results.
Last night i was going to setup my rockers and did a little testing with a dial.. 1/4 turn i'm pushing 10ths preload, I consider 0 lash when i start to feel resistance spinning the pushrod. After reading the directions it appears these require 1/8th turn which puts it in 4-6ths preload range and as far as i understand this is correct.
My concerns are..
what does everyone else consider 0 lash
Are the 875-12's really a problem..
under 6000 rpm motor, under .525 lift
how much preload/turns are you guys putting in
Last time i set this up it was factory 94 rockers and i did a half turn and got to do it again on several making noise so i'm really on the fence about this 1/4 turn 4ths preload.
The lifters were soaked in oil.
Thanks again
Brock
My concerns are..
Thanks again
Brock
