Light-throttle knocking noise
Michael
My Ty started having a light-throttle knocking sound a few months ago. It sounds like REALLY light detonation, but only occurs when at 10 in hg vacuum at moderate speeds (like climbing a hill part throttle). If I increase or decrease throttle the noise goes away. I just try to avoid that set of conditions while driving. There is no audible detonation under any other conditions, although I have always had knock-retard issues when running at the track. I have 100 octane race gas in it now, and it seems to be slightly less noticeable (though that may also be my imagination). It seemed to be there before and after replacing the transmission (stock GM rebuild). The mods are as follows: 160° T-stat, underdrive pulleys, ATR cat-back exhaust, ATR intake & battery relo, rubber IC lines, Johnson IC pump. I have not run a datamaster run yet (needed to dig the old RS232-equipped laptop out of a closet and charge the battery). Any ideas of what to look for?
Thanks,
Michael Pliska
SpoolingTurbo6
Re: Light-throttle knocking noise
It could be alot of things.... get a 3' long screwdriver a place it on where you think the sound it coming from, put your ear to the screwdriver and listen.....Rinse & Repeat !
It could be the con. rods walking around,lifter tapp, rocker noise, or just plain ol 4.3 noise
