Long start when cold
Re: Long start when cold
it still sounds to me like your fuel pressure is bleeding back into the pump, which is why you are getting an extended crank time (pump is running while you crank but it has to push the fuel back to the injectors) but you should definatly replace your batt. and alternator if they're going bad... let me know what you find out...
