Low oil pressure?
JuStBlAzIN
Re: Low oil pressure?
jjorgensen52 said:
I did not pull any caps because there was no evidence whatsoever of metal in the oil or the pan, and it wasn't making noises. I never completely lost pressure, so I wasn't too worried.
I had 65psi idle before, but I also had a high pressure spring in the old pump, which I do not have in the new pump. oil is Synthetic Mobil 1, 10W30
Sorry to Bring Back and old thread, but i am having similar problems. Did you remove the trans to get the pan off?
jjorgensen52
NHSTE - I'm the only one!
long time since I updated:
1. No, trans did not come out. Access cover comes off and the diff has to be dropped.
In the end, this was all a wild goose chase. I broke 4 of my lifters, which allowed pressure to bleed off. In the process I burned a cam bearing (but since I didn't drive it, that didn't show up). Changed the pump as a precaution, all 12 lifters, new filter and oil, put it back together and still no pressure. Presently apart getting bored for oversize cam bearings
Tooky
Serious about performance
It appears that your stock crankshaft has been converted to internal balance??
Do you recall the cost to do this vs. the cheap external balance that most people do? I've been trying to find this information for years and nobody can tell me the cost to do it.
EDIT: I did a search and found a 5 year old post saying A: It should cost no more than $250. B: Under $500, and C: $1400. I'm looking for a real-world cost from someone who had it done and paid the bill.
JuStBlAzIN
it cost me 400 to have it balanced from a local shop. They had to use magnesium (i think) on the crank. IT was internally balanced.
jjorgensen52
I believe (don't have the receipt in front of me) I paid about $450 to have my crank cleaned, polished and internally balanced. Nice and smooth now :D
