So how can you tell if it is a two bar map sensor or a naturally aspirated map sensor? I have like 6 spare GM map sensors in my garage, how can you tell witch ones are witch? Some have different color plugs.
Or on the top side, looking down at the map sensor you can see the two bar has two tabs on the connector area and the three bar has three tabs. If you look you can see them on the two bar map on the bottom.
actually that black 2 bar that I have has 3 prongs just like all the other 2 bars, so you cant go by that either, really no way to id them from the outside it seems.
