4.8t
Re: marine intake injector size
it had 3.43's in it and they did not pull as hard and it took it out of boost longer between shifts with those. the whole truck runs so much better with the 3.90's he said he could tell the boost came in better with these gear. i have the logs 11:1 afr and 95% duty cycle. its not a 3500 pound s-10 its a full size ext cab silverado. takes more power to run the same times. i'm telling you what the computer said. hell with 7psi the stock pump was maxed by 4000rpm.
