Messed up boost controll - again
Falco
Worked a bit on the truck in the last few days. Relocated my battery, fabricated an SS pipe with to goes between my cone K&N and the orange hose. Well everything fine, went to a test drive.
And here we go, my boost controll is shitty again. Big spike after the second shift, than it drops back and it takes a while since it's flattening out again. :evil:
Previously it was rock solid. What could I mess up? Could the less restrictive intake have such anb effect? I might partialy removed or kinked one of the solenoid's vacuum hose, will check this. Any other ideas?
Peace,
Falco
Ok, I checked the WG solenoid's vacuum hoses. They are in good shape so far. Now I'm really pissed off. :evil: Tomorrow I gonna loop out the solenoid and put in some kind of manual controll I have somewhere. Will see...
Later,
Tooky
Serious about performance
Don't worry, you're not the only one... You are running stock turbo right? Please let us know if you find the solution. I've found that the chip you are running has a big impact, too.
Falco
Josh,
Yep, stock turbo, stock WG. I know this is a usual problem. What disturbs me that it was good, than suddenly it's like shit again. Add a new exhaust, boost controll went bad, fixed it. Add a new intake, boost controll went bad again. Enough! :x I'm tired of this.
Hooked up a manual valve today. Still have to set it, but it looks promising. Will keep you updated. I decided, I can live without the boost controll in the Ultimate in exchange for flat boost.
Later,
LuvBoost
So this is a common problem?? Mine has been doing the same thing. One day I have good boost and the next I don't. Datamaster looks good. Does the Ultimate have a better handle on controling the WG solonoid? If so, I might not wait any longer to get one.
B
Blake
Guest
Some people have found inconsistency due to an intermittently sticking wastegate arm when it gets hot. There's a high temp lube good to 1500F at most autopart stores. Disconnect the wastegate actuator rod, cram the lube into the joint and work it back and forth for the full range of mov't. Do it over and over till you feel comfortable it is lubed well. Hook the arm back up and take it for a spin.
LuvBoost
i've had mine apart a few times playing with the rod adjustment. The WG is loose but I lubed it up anyway. It didn't help. I was thinking possibly a bad solenoid.
Richme
Do you recall what this lube is called?
TIA,
Falco
Don't know this lube, but I checked my WG when hot. Damm. :x But it was moving freely. Also replaced my solenoid a while ago. Didn't help. BTW, I'm sporting the Ultimate and all my boost controll adventures was with it.
Later,
