Motor rebuild question
BadForm
Are the '96+ Vortec blocks similar enough to be a drop in replacement?
The reason I ask is that they seem to be cheap enough that it would make sense to buy a whole motor, and rebuild the bottom end of that engine while I still drive the truck around, then swap and save the original engine for later.
Or should I just hunt down a set of heads, and an earlier block (that doesn't make as much sense to me somehow...)
Thanks!
Falco
Read this for example:
http://syty.net/phpBB2/viewtopic.php?t=15032
To summarize, get the late model heads and an older block. If the older block not from a SyTy you should change the caps... :-? You should also redill/retap your Vortec heads and modify your intake to be able to use the new heads.
HTH,
