Aeroking
e.i.
I'm running a multi-stage manual boost controller with my external wastegate, and i'm having a really tough time getting the thing to cooperate. my target being 15psi in the 1st stage, and 23-24psi in the 2nd stage
the controller is 2 manual bleeder valves, connected by a solenoid switch. with a course boost adjustment ball/spring.
when i plumb the system using only the bottom WG port, the turbo surges to 26~27psi in overdrive, no matter what spring i have in the wastegate. The controller works for a second, then the turbo just pushes through, and overboosts.
When i plumb it so that both wastegate ports are in the system, all i get is the spring rated boost, in both stages.
