My engine knock - what happened?
johnboy89
Re: My engine knock - what happened?
Would the meth kit spraying early really cause this? I would of thought it would just run richer and maybe bog down the engine. If it were spraying before it was suppose to ,would it be enough meth to hydro-lock the engine?
I agree and have the same kit and mine turns on very low around 2 PSI.
What was your alky level at the time, if you were out or system was not working and you detonated??
TrboSy2051
The meth tank is half full. Pulled the head gasket and still nothing is jumping out at me. I'll just finish breaking it down and keep pressing with the rebuild. It's getting new heads and injectors so those will be crossed off. The block will get checked at the shop.
Thanks for the help
5678TA
I have a hard time believing this was a blown head gasket. It takes time to fill the cylinder. At idle speeds, i could slightly imagine possible but most i've seen just start blowing steam then eventually they let it idle and she dies. The pressure of the cooling system pushes coolant into the engine and its hydrolocked. Stuck.
Maybe KR plus worn bearings could have jolted the rod enough to start bending. Additional KR and/or boost pressure finally contributed to the further loosening of the rod and bang. GM factory rods are notorious for being softer than toilet paper.
On the topic of meth kit contributing, some quick math calculates an intake stroke to last 0.03 sec at 2000rpm. (i think thats correct) You cant fill a 64cc chamber that fast even with a meth kit and injectors flowing max capacity. Thats over 2 liters of volume per second. A walbro does 255 liters per HOUR or 2 liters in just under 30 seconds. Thats max flow on the outlet of the pump with no injector restricting it. A meth kit is not going to flow much more, plus that would need to be a direct stream into the individual intake port, not at the throttle body dispersing into 5 other ports. Even catastrophic head gasket failure would have a very difficult time filling the chamber to the point of hydrolock while at speed. He would have noticed an extremely difficult time starting her back up, post HG failure. They dont just stop leaking all of a sudden.
Then after all that, if the meth kit was working and the tune was decent, little to no KR should have been present. IDK WTF i'm talking about. Time for bed.
TrboSy2051
Good info on the links. I pulled the rod out and the bearings look fine for a 113k motor. Kinda shitty nothing definitive was found on my part, someone with more experience would probably see it.
Thanks for the inputs and education.
