A
amerimuscle99
Guest
Ok so I have Syclone #1376 with 110K. I pulled the motor because I was thinking about going LS. I have now decided to put the votec heads that I have on with a cam. So I need help with picking a cam and a converter. The guy I bought the car from said the trans was built but I'm not holding my breath. I'm thinking of just keeping the stock turbo and purchasing Holley HP EFI. I don't want to shell out a huge amount of money right away. I want to get it back on the rode driving while I get more parts put together.
I do have a used ITS 66mm I could throw on. I don't know anything about it but it seems good to go. I would need a T3 to T4 adapter to use the turbo. Would a adapter make the turbo too high. The one I was looking at is around 2" tall.
ok so....
stock block, pistons ,rods
aftermarket cam ?
stock vortec heads
stock vortec valve springs
stock vortec rockers
stock intake
Kenne-Bell A2A
60lb injectors
ITS 66mm
Holley HP EFI
Torque Converter
700r4
aftermarket wastegate ?(located on crossover pipe)
Eventually it will have a built v6 or LS Motor.
Thanks for the help I am new to these cars. I have been in the LS world.
ok so....
aftermarket cam ?
stock vortec heads
stock intake
Kenne-Bell A2A
60lb injectors
ITS 66mm
Holley HP EFI
Torque Converter
700r4
