Need help to identify turbo
1BADV6
I have a stock syty turbo that has a different impeller than stock. Does anyone know what it is? I have attached photos showing what looks like dual fins.
SY2455
70's Veteran
Re: Need help to identify turbo
Pictures are really bad , but it may have a 20G impeller.
1BADV6
Dave -
That looks like a 20g.
Mark,
It must be some sort of a hybrid, or has been upgraded to a 20g wheel. Externally it looks just like all the other stock turbos I have. I added a few photos of the entire turbo. It came on one of my Typhoons and it did seem to run better than a stock truck.
thanks,
Maxtor
There should be a number just inside the exhaust housing inlet stamped into the casting. It will be an 8, 10, 12, or 14. What does it say?
1BADV6
I will take a look this evening and let you know.
thanks
SY2455
70's Veteran
Seeing the better pictures, it really looks to be a 20g impeller. I have 2 of those in the garage, 1 with a 8 in the exhaust and 1 with a 14 in the exhaust.
It's just a six
Super Member
Looks like a stock turbo machined bigger to use a larger compressor wheel.
P.N. on turbine housing?
Size of turbine exhaust wheel?
Exhaust exit size hole? Where the downpipe bolts up to.
1BADV6
I don't see a number on this one, I have 4 other stock turbos and they all have an 8 stamped in them. The casting on this one is very rough and lumpy in the area where the others are stamped.....
1BADV6
The casting numbers on the turbine housing are the same as all my other stock turbos.
Turbine exhaust wheel is approx. 2.550"
Exhaust exit size is approx 2.200"
It's just a six
Super Member
If you take a sanding drum to where the casting stamp size of the turbo is, you should be able to see a 8 or whatever it is.
It's just a six
Super Member
Hmmm, if the turbine wheel is approx 2.550" & the exit hole is 2.220", that would seem the hole is smaller than the wheel?
Sounds like a 8 CM turbine housing ,not sure on the exit hole size, if it's close to 2.5" then I would say it has a TD06H turbine wheel.
1BADV6
I tried that, but it's such a rough casting I can't make out a stamped number anywhere on either side.
Maxtor
The inlet looks like a 20g for sure. Sounds like someone may have used a 20g wheel in an otherwise stock turbo.
KDBL1TY
Its a sy/ty stock 20G made by mitshi should be a 14cm.but if it spooled good an ran a little better than stock it may have been modded to fit the factory 8cm. Im running the same turbo.
Throws
Is a 20G wheel something that's been done before?
-P
Sent from my mwp6985 using Board Express
SY2767
You should sell it to me for $100 shipped and not worry about what it is or is not........LOL:tup:
