Hey guys trying to figure out how to run the antenna wire from the passenger side pillar to the stereo. I'm mounting it above the rearview mirror and it is amplified, Need to ground it somewhere? Do i have to remove the dash?
Thanks
Eric
I grounded mine behind the passenger kick panel and then ran the wire along the edge of the windshield along the A-Piller, then around the top and it ends near my rear view mirror. I basically got it right on the edge of where the visible portion of the glass is and it doesnt seem horribly noticable.
I guess I should add...when I ran the wire from the radio, I took out the back panel from the glove box, removed all the lower dash pieces and just snaked the wire over to the side of the dash.
Thanx
How do i remove the lower dash, Is there a thread on here somewhere about it I'm sure. Also, the ground wire is about 6" long coming from the antenna itself, can it be grounded to the rear view mirror?
Sorry, noob to all this car audio stuff
There's a ground wire in the harness that goes into the rearview mirror.
Black is ground. If it needs power (you posted it was a 'powered' antenna) you can use the pink/blk for power. It is hot with ignition on.
91 and 92 have only these two wires. 93 also has a white and orange wire, but use the black and pink/blk which are the same functions as 91 &92.
