MYYellowTY
Ok trying to pass smog and think I have a stock injector thats dripping.I knew which one it was when I pulled them a year ago because thecylinder was wet and fuel washed.But I threw them on the shelf till now and now I dont know which one it is.Any suggestions?The FP leaks down and its not the pump or regulator because it didnt do it with the 42#s that I just took out.Was hoping to put a 38# in for the one and smog it.But think this might work-----------------
Stock injector----321 cc/min--- @43.5#
38#s--------------414cc/min-----@45#
415cc/45=9.222cc per#psi
321cc/9.222=34.8#psi
Correct???? If I put the 38#s in and drop the FP to 34.5#s it should be comprable to the stockers for emission???? Then I can just turn them up some after the test. Am I right or do they not work like that??? Need some help ASAP, itchin to get it back together but with which inj????Thanks!!!!!
