Need help with profec b
spooldup
Super Member
I just installed a profec b on my ty. The only mod i have is the ultimate chip. The boost control was not working well for me so i installed the profec. I hooked the profec up properly and double checked with greddy on that. The problem that i am having is i cannot increase boost past 13psi. Greddy seems to think that it has soemthing to do with the ecm controlling base boost on the gate. I have tried the ultimate on all t1 settings up to 22psi and nada. Any help appreciated. O the way that i have it installed as follows. The out part of the solenoid goes to the gate. The in part goes to the compressor housing. I have the stock solenoid capped and plugged in. I tried unplugging it also but that did nothing.
steve-o
check the units' boost reference from your engine. do not use the compressor port as the controllers' reference. you should run a vacuum line from the brake booster port of the plenum to the nipple in back of the controller as your reference. while you're there, check your dip switches (labelled 4.3.2.1). 4 and 2 should be up, 3 and 1 should be switched down. **these dip switch settings differ, depending on the type of wg you run. mine are switched different cuz i run an external**
it sounds like you have the greddy solenoid connections right and you did good by capping the stock one too... i took mine off and chucked it alltogether.
zip-tie all your connections.
i have the .pdf of complete instuctions in english on file (2.6mb). i can email it to you if you need it. hope this helps.
