need help with tuning 101
cvcsmkr
first off, i did a search and most of it is over my head. so i need help with the basic's.
Ok truck has 65k miles, afpr, a2a, minigate w/boostvalve,ultimate v9, etc.
i have been using datamaster for quite a while on the truck.
i really dont know what the next steps are to get it really tuned.
i was going to get a wideband, but then i thought the only thing i really know how to adjust is the fuel pressure.
any advice greatly appreciated.
Jimmy
Banned
Re: need help with tuning 101
Get in touch with Phil Long.He can optimize your chip calibrations to your mods.Once you got the truck running top notch,it's all in the hands of your chip.
A WB02 is great for making sure your A/F is correct,but really it's all in the fuel and timing tables (which I know nothing about,and have no desire to learn when Yoda (Phil) is readily available)
10secTy
Sy-Ty builder and Tuner
What are you trying to tune in? WOT or drivability or Both?
Is there a specitfic problem with the tune? bog when you floor it etc?
At Wot you will want zero knock counts and 02 Mv in the 920-930 range on pump gas.
Timing and boost will vary with how good your turbo and IC are and the pump gas you have.
On pump gas I just leave it rich and make sure I have enough fuel so I have zero knock. Timing will be in the 14-16 degrees range at 14psi.
Nolan
cvcsmkr
i want to tune drivablilty and wot but mostly wot.
nolan
why do you leave it rich?
wont you make more power the leaner you are?
but also get closer to having knock?
AUSyTyIN
Unbusted $#it box
nolan
but also get closer to aving knock?
Lean is mean, right :roll: . Yeah, mean on parts. Most of us look towards parts longevity, and not max power.
