seem to remember that the buicks will take more knock than our motors will. 0 is the best but a 1 or 2 isn't the end of your motor. the number you said could be though! expecially if you are runnin stock rods and pistons.
you can set the alcohol to come on wherever you want, but are you sure the system is working? hoping it's spraying the amount and when you want is one thing, but if it's gummed up or empty or malfunctiong and not working it could be disasterous on your motor.
i don't run race gas because i like what it costs. i just don't ever worry about whether the octane is working as long as it's in there. clean your system and make sure the pump and everything is working to assure the spray you think you're gettin is actually whats coming out. could be too much timing too. your intercooler are great. little more fuel pressure might not hurt, although your o2 doesn't look too bad. remember, all these thing run a little different.
i now you know this, but just to reiterate for anyone else readin
knock comes fromthese basics:
too much boost, heads too good, headers. basically flowing too much air per fuel
not enough octane
not enough fuel because injectors are too small, not working, or no fuel pressure. could be a bad pump
too much heat in the intercooler
bad tune or screwed up chip
i would turn things both up and down and get rid of the knock and then start again;
