ok drivers side valve cover. the breather that is over there is smoking so took it of cleand and put back on. still smoke. It only smokes when i give it gas. And it smokes out of the breather hole with the filter of.
white is coolant out the exhaust, comming out the breather hole he would need a severly cracked head to get it to come out there, and it wouldnt run Check you PVC system make sure the hoses arent plugged.
