Need to learn some stuff
Im starting to get pretty familiar with learning the in's and out's of an ECM, but there is still many things that confuse me, is there any place or site that i can get some info, all the better on the way the factory ECM's work, i have been doing alot of work with a snap on scanner with numerous vehicles, my next question is when my truck is running again, i have the old DFI setup for it, im still confused on baselining things then going for performance and then tuning to be safe, is there a known middle point to start at???one other question, when in open loop does the comp use the sensor's info or its own stored info per coolant temp and so on to control fuel enrichment and so on...
thanks guys
JoeLutz
I can answer one of your questions. Open or closed loop just has to do with the O2 sensor. When in closed loop, the ecm reads the O2 sensor mV to adjust the fuel mixture to try to get it close to a desired value, usually stoch 14.7:1 at low throttle cruise, etc. It alters the fuel mixture by changing the S-terms and L-terms. Open loop, the ecm doesn't car what the O2 says, it just uses it pre programed values. When you are at WOT, the ecm is in open loop.
I think you may be getting confused with the "limp home" mode where the ecm uses some preprogramed values if a major sensor such as the map sensor goes out.
