conlyn
On the truck when purchased: (taken from scott kilpatrick's G.A.S.T site)
Johnson IC pump
Custom HTP Chip (would like to know more about it)
External Tranny Cooler
GM Deep Tranny Pan
Electric Fans (can i remove the stock fanshoud since these have their own?)
Rerouted IC lines
Catco Converter with muffler deleted
160dF Thermostat
EGR Blockoff
Autometer gauges
Added by me:
K&N 9x5 Cone Air filter in place of battery
Adj. FPR<~~~~~~~~ set at 43 with vacuum line removed(also tried higher)
Relocated Batt.
fuel filter
Walbro 255 HP
SS turbo2IC w/ HKS SSQV BOV
Gilbert Front Prop. Shaft
fresh tranny/engine oil/filters
I just got my truck back on the road after weeks worth of work on it (a/v and fuel system).
Now i am seeing huge boost spikes upto 24psi, with audible knock. i know i shouldn't be getting into the motor, and i have been real easy on it.
The truck runs fine until about 5psi of boost when i accelerate from 5 the knock starts in and the boost gets rather sparatic going from 7-20 or just sticking at 15 but with knock.
When rolled into it builds boost fine until about 15 psi then it starts breaking up.
Prior to it getting the fuel system and sitting for so long due to the stereo install it would run at 17-18 psi all day and not knock at all.
I know it's not the motor because it doesn't have any problem revving at all in neutral (no, i didn't hold it to the floor :roll: )
Where should i start looking
I checked the vacuum lines going to and from the boost control and the wastegate. i don't know if it is a turbo issue, a ecm issue or my truck is just falling apart but i do know i need to get it fixed, so i can go... do my thing again. because driving a typhoon isn't as fun when you can't go fast
gas is fl 93.
i need datamaster!!! my next 'mod' and a short while away(should have bought it first)
Johnson IC pump
GM Deep Tranny Pan
Rerouted IC lines
160dF Thermostat
EGR Blockoff
Autometer gauges
Added by me:
Relocated Batt.
fuel filter
Walbro 255 HP
gas is fl 93.
