No oil pressure?
the baPhoon
So i found DTC, and got the truck started up. Off the bat i noticed zero oil pressure.
Lifters screaming their little asses off.
I reached back and checked the sender/switch on the back of the motor and everything seemed O.K.
No no leaks in the engine compartment or underneath.
Any clues fellas? I just wanna set my damn timing and drive this damn thing! haha
ty166
Re: No oil pressure?
was the dist. out ? are you sure the oil pump shaft is seated in the dist ? i'd pull the dist and use a drill to prime the pump and check oil pressure.
the baPhoon
Oh yeah im not gona start this thing untill it has oil haha.
Yeah the dist was out for a while. What all do i need with the drill to prime the damn thing? Hopefully ill have whats neccisary.
the baPhoon
NM, searching for a long screwdriver to cut up as i type this. Should have the pump primed in no time.
ty166
there is a tool made for it , but the screw driver works fine also , i have the tool for it but also have a large screw driver with the handle cut off and a socket welded on the other end (so it doesnt slide out of the shaft when spinning)...... trust me , wled the socket on the blade or you'll be tearin that motor down again to find the socket when it launchs inside the motor. i would prime it till you get good oil pressure and then keep primin it for a couple more minutes.
the baPhoon
hmm.. no welder at the house so i might just have to pick up a tool from vatozone.
If they have it heh.
