Not making good FP.
TYTILIDIE
METH HEAD
Got a chance to play with the truck today. Since last tiem I posted about my tune, I have run only a few scan and they were for idle to find out why the truck was surging. Well I tried going back up to 19 PSI recently only to blow some smoke and get some audible knock. So I took the hood off today to do a good FP test. First thing I noticed was that on tip in acceleration FP would drop from about 58 down to 55 but would flutter for the first second then steady out. So When I got to my testing grounds, I lowered the FP to 50. Now, Fp would go up to 55 and stay there but no matter how far I turned the reg out, it would not go above 58. My 02's are dangerously low and I quit doing my runs due to the 5-600 O2mV. This was on 16 psi. Knowck was up at about 9*. IAT's were ridiculous at 178*. INJ DC was only at 70%. Now I know that I can do far better than this because with my current setup when I first got it running good (before I started having fuel problems) I was seeing a great tune. 19psi, 148 IAT's, 4*KR and 910 02's.
Now moving along, Im not sure what I should check for for my fueling problem. I have replaced the Walbro with another, I have refrained from using the rubber hose to connect the pump to the line. What I did here was bend the fuel tubing down and out to lengthen it so that I can utilize the stock pulsator. Im not really think Im leaking anything anywhere inside the tank cause it all fit together very tight and very sturdy. When i have a full tank and get on it it will driblble some fuel from the top. Perhaps the lines are not sealed on top. I dont know. I just cant seem to understand why I am having these problems and am hoping someone has some good suggestions. I am going to try and post a DM file here tomorrow. Any thoguhts?
Tooky
Serious about performance
Re: Not making good FP.
Fuel Filter? ACDelco GF481 (from memory, double check www.sytyauthority.net to be sure)
Every SyTy instruction I've seen says to remove the pulsator because it leaks. I removed mine and my walbro pump has been going strong for 5 years.
TYTILIDIE
METH HEAD
Thats wierd, Ive never heard that before. Ive split 4 of those hoses now. It has a new filter on it so I guess Im screwed. Maybe Ill try the racetronics kit and see if it helps. My ECMB fuse is hot as hell.
TYTILIDIE
METH HEAD
So i fixed my Vss and it turns out that the driveshaft somehow got a hold of the wires and shredded em. I fixed those and my IAC and now my Fp is lookin pretty good. O2's are still not where Ild like them to be but much better. My FP problem seems to be heat related. Yesturday I was having the same problem with FP dropping but this morning when it was fresh I went and did some runs and it ran like a champ. FP climbed with boost and RPM. I adjusted it higher up to 58 and still was climbing like it was supposed to. I added a few lbs of boost but it leaned out pretty good when I did that. Its gotten progressivley hottor today somewhere around 90* and so far its holding pretty good pressure. Im not sure now if I may have an intermittent problem.
