O-ring on valves
E.Murray
I'm tackling valve seals in my Ty and have a question. Everything I've seen says the small square O-rings go in the second groove in the valve, but when I pull them off, the originals (or pieces that remain) are all slid down the valve next to the bottom seal. I thought maybe that happened when I compressed the spring, but you have to compress the spring to re-assemble, which just pushes them out of the groove again. Do they seat in the groove when the valves open or am I doing something wrong?
Hope this makes sense...
E.Murray
Re: O-ring on valves
Those are what I'm using. But the little O-ring doesn't seem to stay in the groove on the valve and I was hoping somebody could re-assure me before I did the driver's side. If I have to pull it back apart, I'd rather just do one side...
The advice i was given the first time i did chevy valve seals was to compress the spring first then put on the o-ring.
Black Knight
I Glow Therefore I am
Same here, I spent forever until I got the GM spring compression tool, then figured out to put them on after compression.
Also I used the O-rings and the umbrellas and everything is all good :tup:
E.Murray
Aha. So the O ring goes on after you put the spring back on the valve, but before you put the keepers on?
