O2 mv question
would a bad injector cause the o2 volts to be low? I am only getting 880-900 on 93 octane and around 4-8 deg kr. I have tried rasing the fp and I am at 56 psi at idle. I have a pitbull chip and it seems to run verry rich at idle. But my sterm and lterm are at 128 at wot. At idle the sterm will get down to 85-90. I just put ur6ix's in it they are gaped at.032. the old plugs looked alright except no4 and 6 which looked like they were running rich.
B
Blake
Guest
I'm still learning this stuff but I do know this(others will chime in I hope). The Short term and long term fuel integrator will default to 128 when at WOT because your ecm goes into "open loop" mode and reads strictly from the tables on the eprom. Your O2 mv are an indication of fueling but only gives an average of the 6 cylinders. Check first things first. Change fuel filter to rule it out as a blockage. Any work done under the truck that could have kinked a fuel line? Oil contamination will also reduce octane of fuel and cause knocking(all it takes is one cylinder to knock). Of course it could be a bad O2 sensor as well. The engine has to be up to a certain temp before the system will go into closed loop. I say that because once the engine is up to operating temp, the O2 mv start bouncing up and down fairly quickly.
Blake
Have new fuel filter on. no lines are crimped. fp raises 1# for 1# new pcv valves . setting at idle the sterm bounces around but stays to the rich side lterm stays at 128 all the time.
