O2 mvolts
0966Sy
Code what?
100% or 120% both are static operation, meaning the injector is fully open and not pulsing through the 4 stroke cycle. Stock base FP is 42psi? I would think by increasing Base FP with an AFPR would allow the injectors DC not to go into static operation under high engine load(max 15psi). Im sure this has been done using the stock prom. Considering if our knock is actually being caused by going lean under high engine load(Stock FPR&Walboro 255). then this could be an easy fix while still retaining a mostly stock truck.
Also getting rid of our knock will somewhat give us better boost control then what we are seeing with the Knock.
When i can figure out how to post DM files, i'll try to get mine up for comparison.
sy538
Good point. Let me rephrase that, I wouldn’t be worried about 99% injector DC. When I run Sunoco 94 I have very little knock, and even less that I think is real. Yeah I think the knock that I did have was because of going lean because changing to the 255 fuel pump eliminated 95% of the knock that I did have. I guess an AFPR is the next step and see what effect that has.
smeagol
Ok, unless your BLM at WOT is anything other than 128, adjusting anything OTHER than the calibration will not do anything for the injector duty cycle. Read that again. The calibration does not care if you adjust your fuel pressure, add 8 Weldon pumps, put sugar in your gas tank.
If your open throttle BLM is adding fuel (> 128), then it will increase the injector duty cycle at WOT. If you increase fuel pressure, or replace your pump, or anything that results in reducing your BLM back to 128 (neutral), you can lower your injector duty cycle.
Syty's and GN's for years have been run on static injectors. While I don't think it is a GOOD idea, it hasn't caused problems. There is something to be said for running 65-80% duty cycle. Also, your injectors may go static as early as 80 or 85%.. it really depends on the injector. Some will stick open at an early duty cycle, some will go static 'later'.
So go check your BLM's; you'll find out really quick if adjusting your fuel pressure will make a difference in injector duty cycle.
Also, keep in mind that this does NOT mean that if you are going lean, you just need larger injectors. Your pump may be going dead, you have may a clogged line (fuel filter etc), you may have a bad injector or two, or they just need to be cleaned.
sy538
BLM = LTerm counts?
LTerm counts are almost always 115-120
STerm counts are almost always 128
So less then 128 the computer wants to deliver less fuel?
But the BLM won’t make it deliver less fuel only more right?
Why would it want to deliver less fuel when I'm so close to being lean?
At wot I’d say average O2mv is 900-910, it goes as low 880 and as high as 925.
Should I just not worry about it as long as I’m getting so little KR?
Thanks for all the info/help/patience.
