Lynn D. Brown
Guys,
Do U think the Bosch O2 sensor is OK ? That's all O'Reillys' has - #13077.
I'm running the wires on the Pass side of the engine - some Q's :
1.) The long thick black lead with a bolt-on circle connector - where does it go ?
2.) There doesn't seem to be a connector for the gray circular electrical port on the back of the AC compressor. Should there be one ? I found the flat black connector for the front of the compressor.
3.) I have a PTE-63 turbo. There is already a connection between the compressor case and the WG actuator. So how does the stock WG solenoid fit in here ? Surely U have to have some kinda control over the boost.
