oil & coolant lines
92 Ty 1173
While pulling my passenger side manifold off I found that my coolant line is pretty rusty and it is unavailable through GM. Also my oil return is leaking like hell any ideas where I can get new ones or any suggestions on fixes I could do. Thanx
blk97ta
Re: oil & coolant lines
i have the stuff you are asking about ! as long as you aren't looking for the braided line !
92 Ty 1173
What do you mean? I'm looking for the pre-fab hardlines/hose with the fittings. If not available can the oem's be retro-fitted with something else?
blk97ta
you're talking about the oil return line (it goes down to the oil pan ) and the coolant line (it's a steel line that ends like a ring i think ) if these are what you need then i have them ! off my 73k sy
jwaller
Evil Genius/SyTy Guru
mike lee sells the oil return line in braided hose and fittings. and I have a few good coolant lines if you want to replace those.
92 Ty 1173
Where can mike be contacted at?? I'd like to go with new line if I can get them. Thanks anyway blk97ta.
moronmechanic
I like to use natural gas lines for my turbo drain line. They come in copper and stainless, they have ribbs that work like heat sinks.
-Chuck-
