oil pan ?'s
not sure if i read something about this or if im going crazy , is there a GM factory pan that clears the 4 bolt caps better than the factory one?
i gotta pull the pan off my truck and i hate the way it fits with the caps
thanks John S
Falco
AFAIK, no. What kinda capd ar you using? I'm using Pro-gram, and don't have any problem with them. I had to bend the dipstidk tube and bang out the pan for the Eagles, but no clearance problem with the caps...
Later,
jwaller
Evil Genius/SyTy Guru
the only issue with pan problems is if you used something like the moroso caps. they were so long that the nut on the inside of the pan for the strock oil return would hit. this could be fixed several different ways but the only thing normally needed with pro-grams or GM caps is to clearance them for the rods.
