Oil Pan
gkrcr882
SyTyless......for now!
Do the SyTy's use the same oil pan as a regular 4.3L S-10/15? we need to replace one with a rock hole and need to know if a regular pan will work. thanks!:tup:
NecroWolf
lost marbles member
Re: Oil Pan
it looks like it's the same one as a 4x4 s10. i'd try it don't see why it wouldn't work depending on where the oil lines for the turbo are plumbed at
VermontTy
Support Our Troops
Re: Oil Pan
It's gotta have the hole in the passengers side for the turbo drain line. You can probably just drill a hole and install the fitting from the old pan though.
Re: Oil Pan
The oil pan is unique to the Sy/Ty's. The hole on the passenger side of the oil pan for the turbo drain fitting has a nut permanently welded in position, so the fitting can be threaded into it. The part number for the pan is 14097275. List is 109.94, but a good price would be somewhere around 70.
Captain Morgan
Moderated User
Re: Oil Pan
yep, I just sold my spare one for $70 the week before Nats.
gkrcr882
Re: Oil Pan
thanks for the info! where did you order your pans from? would a local GM dealer be able to get one? thanks!
vortecfiero
Re: Oil Pan
for what its worth
i drilled a hole and had a $ 2 fitting welded on to my stock pan.
if you are handy it is a more "budget concious" way to go
craig
VermontTy
Support Our Troops
Re: Oil Pan
vortecfiero said:
for what its worth
craig
You also put a turbo on a fiero. :tup: I am sorry, but we can only take you so seriously Craig!! :rotf:
gkrcr882
Re: Oil Pan
we dont have access to any welders, so modifying a regular pan seems like it wouldnt work. where can we get an O.E. pan? can one be orderd through a GM dealer? are there any companies out there that make replacement pans for SyTys? thanks!
vortecfiero
Re: Oil Pan
*grins Noooooooooooo lol
I put a turbo on a 4.3 ... in a Fiero
