OIL PUMP Q
nightdiver
I had i high volume oil pump and i found after 15000 miles the top rod bearings red
Should i boost the new HV oil pump a little bit ? Is it possible this to happen from the always low oil temps ? i mean i never saw more than 180* .Normaly it is around 140*- 160*
Lynn D. Brown
Oil Pump
Oil Pump
Your questions make no sense. How could the top rod bearings be red ? U can't boost the oil pump - altho' U could put in a stronger bypass spring to get the pressure up some. Oil Temps of 140-160 - sounds more like water temps.
nightdiver
The temps are right cause i have an external oil cooler.The sender is located on the oil pan
What is that you dont get ?
The HV oil pumps that we buy are moded just with a harder spring
I know cause i opened three pumps and saw that
The bearings are half red to the rear side!!!!!!!!!!!!!!!
My minimum oil pressure was 30-40 psi when hot
nightdiver
I never use that kind of shit
One thing i found when i was cleaning the parts was that the fitting to the oil cooler was 6mm only .
I think it has to be 10 mm , this could be the problem cause there was pressure but not flow
myclone
FYI on oil pumps.... Im no oil pump expert but have learned a thing or two from my own experience with the SBC/4.3 oiling system and reading car mags the last 18yrs. This is mostly my opinion too.. Other ppl may think Im a dufus (hell, I do) and may not agree. Sokay..
If youre using the stock type oiling system and a high volume pump you should keep an eye on the oil pressure if youre gonna spin the engine way up there in rpm (above 6k IMO). It can drain the pan at high RPM and suck air which kills the bearings (BTDT). Not a lot of capacity in the stock pan for NASCAR rpm levels.
Another thing is the filter bypass. This is the little disc thingy thats "swaged" into the hole in the block under the oil cooler adaptor. If you dont mod it with a stronger spring or shim the existing spring with a HV or high pressure pump youre causing more oil to bypass the filter.
Ive personally had the best results (IMO) by using a STOCK oil pump but retrofitting the LT1 (old LT1) spring into it and pulling the swaged bypass out of the block and shimming it with a ~1/16" thick washer. Reinstall the block bypass (its a PIA!!) and youre done. A word of caution if you mod the block bypass... Let the eng oil get a little warm before you beat on the eng as you will run the risk of blowing the oil filter apart or possibly blowing a oil line from the thick oil and pressure. Ya shouldnt be beating on a cold engine anyway :wink:
Opening up the oil passage in the rear main cap so its nice and smooth doesnt hurt either IMO.
This is all just my opinion so take it for what its worth. :wink:
nightdiver
I went to the machine shop today. The guys are customers of mine and we studied the oiling system.(needs some time)
All the oil that the pump send goes to the filter, then to the oil cooler and then to the oil gallery bla bla bla
So the problem is the restriction to the oil cooler adapters that was 6mm only.
I had pressure but no volume..........
