Throws
Re: Ordering L-35's....Help!!!!
I ended up talking to a couple of people.... best suggestion I got was that the Manley "budget performance" would be fine for the Ty... we're not running the valves hard enough or for the duration that would need them. So, I'm getting them all for $6ea. Beats $19ea for the higher end.
For sure the 7/16 setup is going to be worth it.
For the rest of your list, I'm going to do a port match myself.... after trying it on a set of junk heads.
-P
Ok guys, I could use some help on the my heads from anyone that has or is running built L-35's. My builder is asking me all kinds of questions on the machining of mine. Open the the exhaust chambers, stock length push rods, Ferrea valves etc.
So far, I am having them setup for 2.00/1.6 valves, port & polish, with radiused valve, undercut, beehive, and drilled for 7/16 ARP studs.
Anything else I should do?
Do I need Ferrea valves? I was thinking of just using Manley's
-P
