Re: over boost with new setup
first off you need to place a loop of vacume line directly between the turbo source and the actuator with out the solenoid in line. once you do this see if it still overboosts. if it still over boosts, neither one of the above mentioned products can lower your boost. a boost controller can only block the amount of pressure showed to the actuator thus increasing boost farther. dumb it down to just a loop of hose, and if it still overboosts then you need to either increase exhaust backpressure or you need to find a way for the wastegate on that turbo setup to work more effectively. if it no longer overboosts then by all means get yourself a controller to play with. also, my past experience is that there is no off the shelf chip that will accurately control boost
e
