PCV on the SyTy
thehemi
I'm (hopefully) going to be putting a turbo on my Vortec '99 S10.
I'm having to get things re-routed as I'm working on modifying the
marine intake manifold for my truck.
PCV on my truck is routed from the air intake tract to the passenger
side valve cover. It comes out the driver's side and goes into the PCV
valve on the intake manifold.
It's been suggested (by a reliable source) to just run the driver's side
connection to the marine intake manifold directly (no PCV valve). I'm
assuming its working fine. But is there any danger of doing this due
to the boost getting pushed into the crankcase?
How is the PCV system setup on the SyTy trucks?
Re: PCV on the SyTy
SyTy have specific PCV valves that will hold up to boost. We have two PCV Valves that are in Pasenger Valve cover with a T, one goes to the Throttle Body (Vacuum Operation), the other goes in front of the Turbo (Boost).
jslezak83
Soon-to-be BoostedBlazer
Re: PCV on the SyTy
where can this setup be baught? i'd like to try and run a similar setup.
Loeryder
Re: PCV on the SyTy
You do not want to plumb the PCV into the intake manifold pressure without a check valve.
Otherwise whatever boost you are building in the manifold will be pressurizing the crankcase.
On a stock truck the Drivers side should plumb into the air intake BEFORE turbo.
There is a port on the side of the stock airbox for the 5/8" rubber hose to connect to.
It is common for guys to just run a breather filter on this side.
Pass side has dual PCV valves, one plumbs into the TB behind the throttle blades, the other into the air intake tract before the turbo.
One operates under boost, the other under vacuum.
phoonTy
Truckless. For now.
Re: PCV on the SyTy
Talk to Scott (UR50SLO), he turbo'd his wife's '98 Blazer with Marine intake. I bet he can help you out. :tup:
QWERTYphoon
Motley Driver Award 2009
Re: PCV on the SyTy
Are there two different PCV valves? On mine the one on the intake says "E" and the one before the turbo says "F". I looked around and tried to find replacements. Every store only shows one PCV valve for sale. Anybody got part numbers?
SkyeTy
Re: PCV on the SyTy
call mike at tucker auto parts, he sent me both of mine labled so i didn;t get them confused
Re: PCV on the SyTy
They are the same and should both be stamped with an 'E', the AC delco part number is 799C. www.sytyauthority.net should have the GM part number listed.
Tooky
Serious about performance
Re: PCV on the SyTy
This has always been a source of confusion. I am almost positive the owners manual and GM only list the one 799C for both PCVs on pass side. While there has been discussion of "one for boost, one for vacuum" here, I haven't seen any official source talking about this mysterious "alternate" part number.. Does one exist?
