I have a 6al2, and it does not have a timing retard function. I use mine for the two step function only. If you search, I believe I have a section of my build thread where I showed how to wire the two step into the cruise control "set" button. This is only ok if you are not using the cruise control on your truck (I removed mine).
When I was running mine with a 2step. I usually launched around 2500. I experienced the delay also. I had a picture somewhere with the green light lit on the tree (Brakes come off on the 3rd amber) so obviously the brakes are off yet the brake lights are still lit. Never figured that out. Built a removable button that attaches to the steering wheel when racing. Works well.
so, at 2500RPM do you just floor it, or hold it around that point? i played with it a bit but didn't seem to build boost that fast, and going way over the rev limiter (by flooring it way past that point) it starts to run really rough.
Getting my truck ready for a tracknight and really need to cut my 60's to get a better time that should be up with my end speed
i was able to spool around 300-400rpm lower with the 2step then just off the converter.
I wired mine to the horn button, i copied from an old thread.
my AFRs were 14.0, or high 13, depending on how much boost i built. The boostwould heold steady for a few seconds. If i turned up the RPM dial, it would bump the boost up. It launches consistant everytime. Once you settle on a certain RPM and PSI to launch at, you can adjust the fuel and timing so that it doesnt run so rough.
