Plug on stock turbo
TYTILIDIE
METH HEAD
Re: Plug on stock turbo
Ok so lets try to get a no bullshit assessment here. To all the pros who know this route, is it the best way to go ? If not, why? Shoudl I just put my external to use? If you need to know my main concerns its mainly saving room and having an "easy" set up.
93ty475
You mentioned needing more top end.....If you fab up a downpipe, you'll get quite a bit more top end....All you need is a flange from JS, a 3" mandrel U-bend or two and one evening of work....After removing my cat and mufflers, I took care of my overboost on my stock sy by raising the fuel pressure and running a leaner program.....
TYTILIDIE
METH HEAD
So you are saying that I would need a chip to do it this way? Im assuming the Ultimate is acceptable being that I paln on buying it this spring.
93ty475
Tyson from Florida sent me a bunch of stock and 50 lb, injector "leaner" programs that he was using to dial in his alky....I put 16 of the stock ones on a moates 55 dollar switcher and switched my way to the perfect one while monitoring the boost gauge and datamaster....Daron gave me the idea about raising the fuel pressure to bring the boost control into check....it sure the hell worked....
p.s. I havent gotten around to fabbing the 3" downpipe for this one yet...I'll post pics when I do...
