Plug wire change
Since changing the plug wires “looks” like a heck of a job (meaning getting everything back just like it was) your opinions on leavin’ em in a 55k mile stocker and just changing the plugs, rotor and cap?
Thanks,
Don
Merk
Its really not that hard of a job, and if you are doing the plugs, cap and rotor, its an extra 5-10 mins to change the wires. Seriously.
Stock wires on my 93 Ty at 30K were brittle, so I'd recommend swapping them out.
If you have ignition issues in the future, you'll be swapping the stockers out anyways. Might as well do it all in one instance.
I've had good luck with KB Redhots and ATR Black Beauties. KB doesnt sell the Redhots anymore, but they are produced by Taylor so check www.sytyauthority.net for the appropriate part numbers.
Good luck!
________
Lovely Wendie
SY2932
Administrator
Do everything. I drive my truck less than 6,000 miles a year and I replace everything every year. For plugs, I would recommend NGK UR5's gapped at .035" a conrad cap & rotor part number DR2012G and Taylor Sprio Pro plug wires. A swivel spark plug socket will make getting to the number 3 plug a lot easier: http://huryde.station180.com/gallery/view_photo.php?set_albumName=mikecampbellakaSY2932&id=aap
Craftsman makes one that works really well: http://huryde.station180.com/gallery/view_photo.php?set_albumName=mikecampbellakaSY2932&id=aaq
A short piece of 3/8" transmission line will make installing the plugs easier and help prevent cross threading them. Don't forget to put a little antiseize on the threads too.
Make sure you get your firing order correct: http://www.whitetyphoon.com/firing_order.html
And use a "tool" most owners have in their glove boxes to help remove the stubborn rotor: http://www.whitetyphoon.com/removing_rotor.html A little smudge of silicone grease inside the new rotor with a tooth pick makes it easier to come off the next time :wink: ...
Lastly, secure the plug wires on the passenger side from the downpipe! If they touch it even momentarily, they are done. HTH's
Mike Campbell
Order, what order
Order, what order
Mike,
Speakn’ of getting the firing order correct a guy I used to know way back in high school thought he’d change the wires on his mom’s Olds. He buys new, pulls the old, and just randomly installs the new wires. The he can’t figure out why the thing won’t run. He thought it was the distributors job take care of such things. Yup, I’m the guy who sorted things out.
Don
