plx hookup
blkty
i am starting to hook up my plx boxes i am using a add a fuse to power it like the detroit turbo video i have the dm200, afr wideband, boost,trans temp,oil pressure to power all those sensor modules do i run all the red power wires to the add a fuse and if so what size fuse do i need and for the black ground wires that come out with the red were do i ground those at any input would be appreciated
thanks blkty
WyoSyclone
Re: plx hookup
5 amp fuse should be plenty. I ran my grounds to a single grounding point at the driver's side kickpanel. Drill a hole, dremel down to bare metal, get a correct-sized self tapping bolt, use a star washer, crimp terminals, and properly crimp with a crimp tool (not a pair of pliers)... that should do it!
blkty
Re: plx hookup
so run all red wires to the add a fuse i was also woundering in the video he is putting capacitators on a black wire and pluging a black wire in the ecm what wire is that
blkty
Re: plx hookup
so the way i understand it i will only have 2 wires coming out of the 4 wire connector on the afr is grey and black witch i guess i gotta go buy some black wire is this right or do i gotta have all 4 wires i am using the dm200 and cant find any videos hooking up the wideband with the dm200 is ther any thing extra to wire up
thanks blkty
