polygraphite vs solid motor mounts
DOMN8R
NASTE Member
http://www.p-s-t.com makes polygraphite motor mounts for chevy 350. can these be used instead of solid motor mounts with the JS designs syty motor mount adapters - if so - what do you think would be the pros and cons of polygraphite vs solid mounts?
ItsMyTy
Life is beter at 25 PSI
just use solid mounts
i have them and there is'nt any noticeable vibration compared to stock mounts and you dont have to worry about them breaking or melting
Lynn D. Brown
Solids vs Polys
Solids vs Polys
Wow, that's pretty amazing. I guess that kinda says U don't need motor mounts, or any flexibility where the engine connects to the frame, huh ?
Say, where did U get the Solids, anyway ? I have the Polys now, and according to alot of the stuff on the list, these may burn out. So, I may need to be getting solids.
sy#2716
SyTy 4 Life
You can either get them from Mike lee at raceprovenmotors or contact e-rue at turbotime.us they can get them for you. jpope
